Export iam to rfa file
I have looked how to export an iam file to rfa.  When I go to export building components, the file type does not show rfa.  Any ideas?
Thanks!
Curtis_Waguespack
Hi nmayrose,
You will want to use the Export Building Components tool.
  1. Go to the Environment's tab > BIM Exchange button.
  2. This will open the BIM Exchange tab.
  3. There go to the Manage panel  > Export Building Components button
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-4435741A-995A-4369-A91D-F7BB40793FA6
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-D90D56FF-11BB-4C2C-BFF7-B426E3CCA348
I hope this helps.
Curtis
Curtis,
Thank you for your reply.  I have gone through all those steps, but when I choose the actual file type to convert it to, rfa (Revit) is not listed.  Only .adsk & .ifc are listed.
Thank you,
Nicole
Curtis_Waguespack
Hi nmayrose,
Would I be wrong in saying that only parts can be exported as a *.rfa ?
I don't recall, but I did a quick check and that is what I'm seeing. But it's been a long time since I've messed with the BIM Exchange tools.
Maybe you'll need to do a Shrinkwrap on the assembly first?
Maybe someone else can confirm this for us?
I hope this helps.
Curtis
Sofia.Xanthopoulou
Hi @Anonymous,
I can second Curtis_Waguespack's statement. Only part files can be exported as *.rfa - assemblies will be exported as *.adsk. You don't need to worry though, *.adsk is also a native Revit file.
And another video on exporting assemblies to Revit Smiley Happy
Is there a particular reason you insist on *.rfa?
Regards
To export to RFA you will need to simplify your assembly into a part and run the recognise revit features command. You may find that you have to rebuild some features if they cannot be recognized as a revit feature.
See below link for workflow diagram
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Cheers
Callum
