Save as stp and open with PTC creo problems
Message 1 of 18
I made a model with Inv2013 and I have saved as stp. When my customer try to open with SolidWorks or PTC the model is broken, looks like has open surface. If I open that stp file with inventor the file dont has problem. Any suggestions?
I have attached the stp file made from Inventor
Replies (17)
Message 2 of 18
CCarreiras
Hi!
This is a multisolid, maybe that's why will have problems. Try first convert the part in only one solid before convert to step.
CCarreiras
Message 3 of 18
CCarreiras
Hi!
This is a multisolid, maybe that's why will have problems. Try first convert the part in only one solid, before convert to step.
CCarreiras
Message 4 of 18
Hi Carlos,
Thanks for your reply, I tried to combine the parts but I cant. Please check the message. If you want I can send you the original file
Message 5 of 18
CCarreiras
Yes, i saw the messages in my system.
Yes you can send me the original and i will give a try. Iyou can send to email if you will.
CCarreiras
Message 6 of 18
Please give me your email
Message 7 of 18
CCarreiras
Hi!
If you click in my name... in the up left corner, you will have all the info about people.. but
here it is: carlos.carreiras@cpcis.pt
CCarreiras
Message 8 of 18
Hi Carlos,
Your email not work, maybe not support big files. Anyway please use this link to download the file
https://www.dropbox.com/s/i3xlgcsnmas9snq/Saab%20J-29%20-%201.1%20-%20Fuselage%20Front%20Part%20-%20...
Ivan
Message 9 of 18
Hi Carlos, Could you download the file?
Message 10 of 18
CCarreiras
Hi!
Yes.
I already manage to join two solids... now is missing to join the last two ones, the body and the wing support... that will take some time. I will see that after work.
The part have a few complicated surfaces, some errors, that's why it can´t join easealy in one body.
CCarreiras
Message 11 of 18
Muchas gracias Carlos!
Message 12 of 18
Hi Carlos,
Any update about my problem? any idea how fix it'
Thanks ind advances
Ivan
Message 13 of 18
CCarreiras
Hola!
I asked for your email a few days ago.
Check in your private messages of this forum, you will have a link to download the part.
Any problem, just tell me.
Saludos.
CCarreiras
Message 14 of 18
Hi Carlos,
Thanks for your hard work, I appreciate. I could open your new file, the stp. I can open in Inventor without problem and dont have any error. But, I still have the same problem. When the manufacturer try to open with PTC creo the dody is a open surface, so they can use that file to make the mould. They need a solid piece. We are in the same start point, why if you have a good solid piece in Inventor when you convert to stp and open with other softwear sometime you can not have a useful solid?.  I have attached a screenshot where show where the surface is open.
Thanks for your comments
Message 15 of 18
CCarreiras
Hi!
Sent to mail.
Ps: Ask your frient to have also a Inventor license 🙂
CCarreiras
Message 16 of 18
Hi Carlos,
Thanks again but the problems are still there. Thanks for your advise but is not easy replace the software in a big company. there are a lot of things that they need modify. Also they told me that only with Inventor they are running with this issue so is more probably if I can not fix this problems that I have to move to other softwear. I spend long time making the models and still have problems...
Any idea how can I make a model and avoid this problems?? Im felling that inventor is not a good softwear to make this work...
Message 17 of 18
CCarreiras
Hi!
Check email...
CCarreiras
Message 18 of 18
CCarreiras
What i can say is i can open the file in other CAD system, like NX, so i can't say if the problem comes from Inventor, NX or Creo...
If it is a good tool or not... it's a cad tool, depend how you create things.
Let´s try one last time... and i believe it will work.
Note: i Believe this is parts for kit mounting models, so you don't need the holes, (very complicated mould system) but the efect it makes, so i delete de holes and leave the form... check it...
https://db.tt/eXaarPWO
say something...
CCarreiras
