Save and Replace function : how to change default folder to last used folder - Inventor 2026
RigazFra
RigazFra
I’m experiencing an issue in Inventor 2026. The Save and Replace option always defaults to the workspace instead of returning to the last used folder. In previous versions, it would consistently go back to the last folder used. Is there away to change this?
@RigazFra Your post title was modified to add the product name and version and to increase findability - CGBenner
Leo_xie
Hi @RigazFra, thanks for your feedback.
I tried this but haven't figured out the key steps to reproduce the issue.
Could you let me know if you are using a default project or a customized Inventor project? Is the last used folder in your project scope? Any sample to reproduce the issue is appreciated.
Leo Xie
Software Engineer
RigazFra
Hi Leo, Thanks so much for the reply.
Sorry I'm not 100% sure on what you mean by 'default project' or a 'customized Inventor project'. I have always created a .ipj project file for each of my clients when creating designs for them. I think I'm using a 'customised project' .
To help explain what I'm asking, I have attached a PDF document that shows step by step on what happens when using the 'Save & Replace' command. I hope this helps.
Leo_xie
Thanks for the nice document. I have reproduced the issue, but failed to find a workaround it. A ticket for this has been created. The team will rank the priority.
Leo Xie
Software Engineer
