Save and move
Save and move
Save and move
i have mad a small misteake when i started my project and i didnt check the option to save all CC parts into my project. If i use option "Save and move" with all relative files will it work correctly? All parts, CC, iLogics, Forms and sources in rules of iLogic? Or what can I do to do so? Please, help.
BeKirra
It sounds like an issue of setting up project file.
Assuming you do not working with vault.
If this is the case,
1) do you use a specific project file for your current project?
If you do,
2) have you setup the content center path with your project file?
3) furthermore, are you the only one working with these inventor drawing files?
If you are working in team in your office,
4) You may need to save your files in a public server and locate the content center folder in the server.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
blair
Do a "Pack and Go" to a single directory. RMB on the primary Assembly File and select the "Pack and Go" option. This will collect all the files and move them into a single path and zip them. Easy to unzip and move to the desired directory.
Delta Tau Chi ΔΤΧ
