Inventor Forum
salvaged view may not be accurate
5 REPLIES 5
CAD-One
4622 Views, 5 Replies
Do any of you guys see this on a drawing view on the feature browser?
Whats the solution?
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
5 REPLIES 5
mercerc
in reply to: CAD-One
Please attach a screen capture or attach a image so we may see what you are refering to.
Charlie M
Inventor Product Support Specialist
jyager
in reply to: mercerc
Attached...having the same issue.
Seems like everything is fine...just get an error prompt when trying to add part balloons
Jason Yager
Inventor Professional 2025.0.1
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
t_pcoll
in reply to: jyager
Hi Jason,
some bodies in the model are bad so cut them in section view failed. Bad bodies should be listed in the results dialog. They need to be opened in part environment and see if they can be repaired.
If you can send your dataset (model and drawing) to ladislav(dot)pcola(at)autodesk(dot)com then I can take a look at this in more detail.
Ladislav
gkulas
in reply to: t_pcoll
What results dialog would show this?
johnsonshiue
in reply to: gkulas
Hi! Please open the assembly and press Ctrl+F7 (make sure C:\temp\ exists). Then the body sanity check dialog will come up.
Many thanks!
Software Test Engineer
Technology Administrators
