Inventor Forum
ROUNDDOWN or Ln (Help)
4 REPLIES 4
1305 Views, 4 Replies
I have this problem that I hope someone can help me solve, I hope its simple...
What im trying to do is to make iLogic Rounddown the d51 (Pattern) by using Ln but it does not work. Any idea why? "See pictures"
4 REPLIES 4
Roelof.Feijen
You can use the code snippets in the Math section.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
WHolzwarth
Hmm. I think, you've been stumbling here:
https://knowledge.autodesk.com/support/inventor-produkte/learn-explore/caas/CloudHelp/cloudhelp/2017...
There are two separate columns in the table above.
Walter
Walter Holzwarth
in reply to: WHolzwarth
I ended up doing this since I could not make it work and I dont know why. But this Works. see pix.fgjhhgjghj.png
SBix26
The reason you could not make this work is that you were trying to use the Ln (natural logarithm) function to do what the Floor function was intended for.  As Walter illustrated, you were simply misreading the table of available iLogic math functions.
Glad you got it figured out,
Sam B
Inventor Professional 2017.3
Vault Basic 2017.0.1
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
