Inventor Forum
Root Element Is Missing
10 REPLIES 10
Message 1 of 11
lancerichmond
6184 Views, 10 Replies
Anybody else getting a long message box pop up saying a whole bunch of stuff about "root element is missing"? This is causing some of my .idw files refusing to update the part and assembly files in the drawings..... See my screenshot.....
Tags (2)
10 REPLIES 10
Message 2 of 11
asiteur
in reply to: lancerichmond
Hmmmm,
Looks like there's an issue with your Inventor Installation.
When do you get this message? Only when opening certain files, or directy when you open Inventor?
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
Message 3 of 11
Only when I start Inventor.......
Lance Richmond
Draughtsman
A division of ACTOM (Pty) Ltd
Tel: 011 607 1739
Fax: 086 524 0757
Cell: 082 778 0765/0825667322
Email: lancer@mandc.co.za
Website: www.mandc.co.za
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
his email has been scanned for viruses and malware, and automatically archived by Mimecast SA (Pty) Ltd, an innovator in Software as a Service (SaaS) for business. Mimecast Unified Email Management (UEM) offers email continuity, security, archiving and compliance with all current legislation. To find out more, visit http://www.mimecast.co.za/uem.
Message 4 of 11
asiteur
Oke that sounds like some of your installation files are corrupt.
I would suggest you do a clean install.
You could try to reset Inventor first with the Reset Utility
But maybe there's gonna be someone else here on the forum who has seen the specific issue before.
Alexander Siteur
LinkedIn
Message 5 of 11
SBix26
My first thought is that it is a problem with an add-in.  Do you have any add-ins loading besides what comes with Inventor?
Sam B
Inventor Professional 2017.3.1
Vault Workgroup 2017.0.1
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Message 6 of 11
mdavis22569
in reply to: SBix26
Turn off your Vault add-in and see if that helps
Mike Davis
Message 7 of 11
@lancerichmond
The problem is related to a corrupt XML file.  Attach to this posting is a good version of the XML in zipped format.  Just exit Inventor and save/unzip the attached XML to the directory in the the message and restart Inventor.  You don't need to do anything else.
Update:  Sorry..  It would help if I attached the file..  Too early..
Mark Lancaster
Message 8 of 11
in reply to: Mark.Lancaster
Thank you for posting this file!  It solved the same issue for me after having tried everything else.
Message 9 of 11
lancerichmond
in reply to: SBix26
Hi everyone, looks like it was my Addin by Coolorange. Their thread modeler is not yet compatible with Autodesk Inventor 2018. Once removed, problem solved.
Thanks for all your help guys....
Message 10 of 11
in reply to: asiteur
I had exactly the same problem, and the Reset Utility took care of it.
Message 11 of 11
forbillian
Awesome Help Mark.  Sorted the issue for me.
Much appreciated!
