I am trying to add ribs to these curved surfaces (solid). I want to make the ribs 5 mm tall and follow the curves in the model, however I can only get Inventor to make ribs start at the sketch plane. How would I go about achieving ribs that will follow the surface and only extend 5 mm out in X direction?
Making the ribs at a 45 degree angle relative to the model Z is required.
Solved by Joe_CAD. Go to Solution.
Not entirely sure what you want here but I've attached my suggestion (Inv2024).
Yes, sorry about my unclear question.
Using a sweep as you suggested might be sufficient in my case.
Here I used a 2D-sketch and projected it to the surface. Then made a plane normal at the end point and drew my rib shape, before sweeping along the projected path. Thanks for the tip @NigelHay!
Hi! By using Surface Modeling techniques, this model can be done much more easily. Please take a look at the attached file.
Many thanks!
Hi @johnsonshiue,
I see what you did, however the ribs are now not 5 mm tall along their entire length. The height of the rib relative to the base surface is higher the further towards Y and Z you get in this picture.
Offset surface & Trim / Splitt.
Kacper Suchomski
I used a different procedure and so I figured I'd share it.
See attached Inv2024 file.
The rib pattern is driven by d44 and d53 in sketch 2.
