Inventor Forum
Ribs at an angle, on curved surface
7 REPLIES 7
Message 1 of 8
kenneth_paulsen
317 Views, 7 Replies
I am trying to add ribs to these curved surfaces (solid). I want to make the ribs 5 mm tall and follow the curves in the model, however I can only get Inventor to make ribs start at the sketch plane. How would I go about achieving ribs that will follow the surface and only extend 5 mm out in X direction?
Making the ribs at a 45 degree angle relative to the model Z is required.
Tags (1)
Labels (6)
7 REPLIES 7
Message 2 of 8
NigelHay
in reply to: kenneth_paulsen
Not entirely sure what you want here but I've attached my suggestion (Inv2024).
Message 3 of 8
Yes, sorry about my unclear question.
Using a sweep as you suggested might be sufficient in my case.
Here I used a 2D-sketch and projected it to the surface. Then made a plane normal at the end point and drew my rib shape, before sweeping along the projected path. Thanks for the tip @NigelHay
Message 4 of 8
Hi! By using Surface Modeling techniques, this model can be done much more easily. Please take a look at the attached file.
Many thanks!
Software Test Engineer
Message 5 of 8
Hi @johnsonshiue
I see what you did, however the ribs are now not 5 mm tall along their entire length. The height of the rib relative to the base surface is higher the further towards Y and Z you get in this picture.
Message 6 of 8
Offset surface & Trim / Splitt.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 7 of 8
Joe_CAD
I used a different procedure and so I figured I'd share it.
See attached Inv2024 file.
The rib pattern is driven by d44 and d53 in sketch 2.
Message 8 of 8
kenneth_paulsen
in reply to: Joe_CAD
This seems like a good solution @Joe_CAD !
