My ribbon is hidden by the model window and on top of my model tree any ideas to fix this?
I've tried resetting the ribbon appearance, loading the default inventor preferences, undocking and moving the ribbon around - nothing helps.
Here's what it looks like:
Me - "have you tried turning it off an on again"
Me - "no"
Good ol restart did me a solid in this case...
Solved by Bendoucette. Go to Solution.
Welcome to the forum. Have you tried maxing your model screen? How about turning off/on the ribbon in the user interface?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I actually just closed inventor and opened it again... it fixed it. I was unable to mark my original post as a solution so ill do so on this one.
Glad you were able to resolve this. At least if it happens again you have a couple of fall back suggestions.
