Rib feature "missing" in Inventor 2015?
I downloaded Autodesk Inventor Professional 2015 a month ago for the class I am taking.  One of the projects is to add ribs to an oval object, however the "Rib" feature is not under the Modify section nor the create section in the 3DModel tab.
I downloaded all the updates/packs today but it is still not there.
Is it somewhere else?  Do I need to download something else?
I have searched in the forum and in the help sections but did not come across any answers.
Thank you!
mcgyvr
If you right mouse click on the ribbon and go to "customize user commands" is it listed in there? (Ribbon Tab..Chose Commands from: All Commands)
Maybe you just removed the button..
There have been some changes over the years to where commands are located.. It may be in a different location..
But if you find it in the customze user commands section and hover over it then it will tell the location of where it is..
like this..
Curtis_Waguespack
Hi kowaleckic,
Try under the Sweep drop down.
I hope this helps.
Curtis
Curtis_Waguespack
Note too that you can ungroup the commands if it helps:
Ungroup commands from drop-down menu
    • Right-click a command that has a drop-down arrow, and select Ungroup Commands from Drop-Down Menu.
The commands from the drop-down menu display on the panel.
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-129D10A7-5768-476F-BE1D-9D208C0FE969
