Inventor Forum
revolving cut
3 REPLIES 3
330 Views, 3 Replies
revolving cut
I make a revolve cut (revolution-2) but it cuts slightly into Revolution-1.I want to only remove material from Extrusion-1.Is there a better way then how i cut off the angle for Extrusion-1.I could not get to work but will maybe Draft work here?
Please see 2015.ipt file attached
Regards
Ray
3 REPLIES 3
mwighton
Instead of putting a dimension the inside corner of the Revolution sketch, use the constrain tools to make the vertec coincide with the project geometry of the first revolve. Attached you can look at the changes I made.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
TheCADWhisperer
My attempt with simplified sketches (see attached ipt file).
Oops, change this dimension in the part I attached. You get the idea.
