Revolve command
Revolve command
Message 1 of 8
Revolve command
When I tried to use revolve command error message is coming. Why?
Replies (7)
Message 2 of 8
JDMather
Manage tab>Rebuild All
Message 3 of 8
I wish to know the reason for having this problem.
Message 4 of 8
JDMather
Manage Tab> Rebuild All
What do you see and read?
Message 5 of 8
Try to delete the 1,125 dimension, that will do the trick.
On one or the other way it is over dimensioned
Message 6 of 8
Solution1 - Change its value:
My view:
You cannot change the value because it is given.
Solution2 - Remove constraints
My view:
Constraints are there in order to have a fully constraint sketch. How can it be removed?
Message 7 of 8
JDMather
You should have written, "I see a pink dimension.  Pink geometry (or dimensions) is "sick" geometry (or dimensions)."
Inventor designates "sick" geometry with pink color. (Haven't we already covered this?)
Delete the pink 1.125 dimension - it isn't needed.  The center of that arc is already Projected.
Message 8 of 8
Yes we have covered this before. Thank you for remembering.
