Inventor Forum
Revision table Alpha
1 REPLY 1
GSK2019
180 Views, 1 Reply
GSK2019
Now when you click on the revision table button, the revision table will put the revision index automatically on numeric. Is it possible that when you click on the revision table, that the revision index will be set on Alpha automatically?
Or that you can remove the Numeric function from it? Since my company only works with Alpha, it seems unnecessary to have this option.
1 REPLY 1
CGBenner
in reply to: GSK2019
CGBenner
@GSK2019
There is no way to remove the option from the dialog.  What you could do is place a revision block on the drawing sheet of your Template, set to Alpha.  Then, when you begin a new drawing it will already be there.  Other than that, maybe there could be some programming option with iLogic?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
@GSK2019
Chris Benner
