Revision in part number
tmlEFCBE
Message 1 of 9
tmlEFCBE
Revision in part number, is it possible? which ads the A  in the part name itself, and not just on idw.
Replies (8)
Message 2 of 9
CCarreiras
Hi!
There's many ways to do that... here's one of them:
CCarreiras
Message 3 of 9
tmlEFCBE
I only have this in my iproperties
how do i get settings like yours?
Message 4 of 9
CCarreiras
Write the equation....
= BLA BLA BLA - REV - <iPropertie you need>
Click apply.
CCarreiras
Message 5 of 9
tmlEFCBE
Works perfect, but how do i get this to change to
Message 6 of 9
DavidWarta
That is not possible without some ilogic programming and would create new files. A pdm solution like vault basic or vault professional would help alot.
D.Warta
Van Halteren Technologies Boxtel B.V., Netherlands
Message 7 of 9
CCarreiras
Your question was simple: how to insert Revision Number in the part number.
I assume it was the RN from the own part, not a RN coming from other file.
Now you know a way to do it. Case closed.
To change it... Well... Inventor can't guess when you want to stablish a new revision number... right?
You have to edit the iproperty.
You can have RN regarding the parts, the assemblies, the drawing documents, etc... but you have to edit it manually.
Example, if you want to place the model's RN in a drawing, you have to create a text box linking the part (or assembly) RN,  and not the drawing revision number (since every file has is own revision number), depends on what you really want to document.
To have a semi automatic process you will need to use an file manager.
Examle: If you use Autodesk VAULT professional it can be managed semi "automatically".
CCarreiras
Message 8 of 9
tmlEFCBE
thanks everbody, i now have something to work on...
Message 9 of 9
CCarreiras
If you explain better the workflow you want to use, probably there's other options to consider.
Good work!
CCarreiras
