- Mute
- Permalink
- Report
Hello, I am working with a print that has the rev block and part rev as separate revisions for company purposes. I was curious if anyone knew a way to make it so that the revision block revision is a property call-out that can be put into a text box using the property drop-down. I know that the part revision has the property call-out of <part revision>, but I was unsure if anyone knew if it was possible to make the rev block revision its own property. The only way I can think of this being possible is through the custom tags in the iProperties, but we are looking for something more hands-off to prevent errors. I am using Professional 2023.
Thank you!
