Good afternoon, Europe and Africa. Good morning America and others.
Well a quick question, can a plate return its diamond/checker/chequer plate feature was save in Step file. The feature can be seen or return in iam but once saved in step it loses its feature
Thanks in advance
Solved by mcgyvr. Go to Solution.
"textures/advanced appearances" are not supported in the step files I don't believe..
Have you tried using all 3 application protocols (Step 203, 214, 242) (see options button before pressing save)..?
If none of them work then that texture is not supported in the non-native file type
