I'm new to inventor, have some basic designing skill by watching some youtube videos. I'm trying to design a 3d-printer. In which I have to place a V-Wheel on top of maker slide
I've tried to assemble it after watching several videos, but none of it worked. Last picture is how it should look like. I moved the v -wheel manually on top of makerslide.
Here's the link to files,
Solved by jhackney1972. Go to Solution.
I was able to create constrain it by using constraints between the mating faces.
Scott Parker
I assume you have the parts already converted and placed in your assembly. The wheel is constrained to the track using two Tangent constrains. After you place each one you may have to flip the solution to get what you desire. Take a look at the screencast for the process.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
@jhackney1972 Thank you so much. I was about to edit question and request someone to put a video in their answer
