Inventor Forum
return mechanism - - how to make a slider move
26 REPLIES 26
Message 1 of 27
1523 Views, 26 Replies
Hi!
              How do I make the slider move?
Thank you.
26 REPLIES 26
Message 2 of 27
the file is attached
Message 3 of 27
here is the screen cast
https://autode.sk/3iPniqz
thank you.
Message 4 of 27
WHolzwarth
The slider will move, if the open slot in Connecting rod1 is changed to simply a hole.
You'd get a sloppy movement with a closed slot with rather short length, but only a hole instead of a slot does a really precise movement without backlash..
Walter Holzwarth
Message 5 of 27
in reply to: WHolzwarth
@WHolzwarth , thanks for your reply.
In my project the slot should be open.
The same connecting rod shall be used in different mechanisms.
That is why it is impossible to calculate parameters of connecting rod for every special case.
I have seen short animated movies on youtube and it works there.
So, I am sure it is possible.
Thanks again!
Message 6 of 27
WHolzwarth
I'd like to see a video of a working mechanism.
Walter Holzwarth
Message 7 of 27
@WHolzwarth
Yes, you are right, it won't work the way I did it.
I will try to find the video.
I have missed something
Message 8 of 27
johnsonshiue
Hi! Is this a school assignment? If yes, please work with your teacher or teammate to figure it out. You need to do the homework by yourself. I can give you a tip. Google the terms "Autodesk Inventor Drive Constraint" and there should be plenty of videos to show you how it works.
Many thanks!
Software Test Engineer
Message 9 of 27
WHolzwarth
I think, it should be similar like that:
https://www.youtube.com/watch?v=rKIoP67_MAI
Walter Holzwarth
Message 10 of 27
in reply to: johnsonshiue
@johnsonshiue , thanks for your reply!
No, this is not my school assignment.
This is my project and
I am not good at mechanics
Message 11 of 27
JDMather
@Anonymous
Is the video that @WHolzwarth linked something like what you are after?
(The assembly as you created it is not stable - it has more than one motion solution.)
Message 12 of 27
in reply to: JDMather
@JDMather , thank you for reply!
What do you mean by saying "The assembly as you created it is not stable "
Message 13 of 27
Here is the base and  concept for my mechanism.
https://www.youtube.com/watch?v=SYYVxnLNzBI&feature=youtu.be
Message 14 of 27
JDMather
It has multiple solutions for the motion rather than a unique solution.
Your assembly does not match the example in the video that you linked.
Note that in the video you linked the pivot point is in a fixed location.
Message 15 of 27
--Your assembly does not match the example in the video that you linked.
--Note that in the video you linked the pivot point is in a fixed location.
Yes, I know that,
but I need one end of the connecting rod to be connected to the wheel and another to the slider.
--It has multiple solutions for the motion rather than a unique solution
it would be great if you could show me the solution which will work for real objects.
Thank you in advance!
Message 16 of 27
JDMather
It will be tomorrow till I get a chance to make a video.  (Maybe @WHolzwarth will jump back in here.)
You can test it yourself.
Suppress the angle constraint that you are using to Drive and move parts around to produce all possible motions.
What do you observe?
There should be only one unique solution.
(Your mechanism works exactly like it would in the real world.)
Message 17 of 27
@JDMather  I appreciate your help!
I will wait for the video.
Message 18 of 27
WHolzwarth
I think, it doesn't make much sense with discussing the mechanism above. The connecting rod needs a change in modeling.
There are three contacts:
1. Pivot point - not on the wheel, but at the fixed base
2. Closed slot for a sliding contact with a pin on the wheel
3. Open (or closed) slot for another sliding contact at the rod's end
After changing the part a new discussion can be started
Walter Holzwarth
Message 19 of 27
Sorry, I don't understand what to be done.
My youtube example is the base for my idea.
I need one rod's end to be connected to the wheel and  another to the slider.
How should I change the rod's structure?
Message 20 of 27
JDMather
You need a pivot point.
It can be anywhere (or most anywhere) along the connecting link.
You will have a lever.
Think of a child's teeter-totter playground toy.
The pivot point is usually adjustable.
