Inventor Forum
Retrieve model annotation
11 REPLIES 11
Message 1 of 12
1526 Views, 11 Replies
Retrieve model annotation not working individual part drawing in weldment preparation. Ref. attachment.
11 REPLIES 11
Message 2 of 12
Sergio.D.Suárez
Hi, I apologize for not fully interpreting what you need.
Could you give us a little more detail of what you are trying to do?
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 12
Cadmanto
Are you talking about retrieving the dimensions from your model into your drawing?
What are the steps you are doing and where exactly is it failing?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 12
johnsonshiue
Hi! It should work. Please share an example exhibiting the behavior here.
Many thanks!
Software Test Engineer
Message 5 of 12
in reply to: Cadmanto
yes we are on the same page. I'm trying to get the model dimension using retrieve model annotation from idw. The assembly was a weldment. I'm detailed that part using base view - model state - preparation directly from the weldment assembly. While I'm trying to retrieve the model, dimension not selectable.Annotation 2019-04-04 161117.jpgAnnotation 2019-04-04 161155.jpgAnnotation 2019-04-04 161311.jpg
Message 6 of 12
johnsonshiue
Hi! I tried the workflow but it does seem broke. I need to work with the project team to understand the behavior better.
Many thanks!
Message 7 of 12
Martin.Tomko
according to the last picture it seems, that Select Dimension Source button, from Retrieve Model Annotation dialog,  is still active. Because of this, are Ok/Apply buttons disabled and dimensions cannot be selected. Disable this button firstly, and then try to select dimensions.
Martin
Message 8 of 12
in reply to: Martin.Tomko
Yes it is working. Thank you.
Message 9 of 12
Needing to unselect the select source button in order to continue is very unintuitive, nor does it match how Inventor typically works (selecting things then pressing okay). Is there a way this could be changed?
Message 10 of 12
DI3P0SEDS26UB
When retrieving model annotations in a drawing (Inventor 2019), some of the annotations (in my case, dimensions) do not appear. Have attempted to update the drawing. Dimensions still do not appear.  Has anyone else had this problem?
Message 11 of 12
Hi! The only logical explanation is that the sketch is parallel to the view direction. Otherwise, it sounds like a bug to me. If possible, please share an example (zipped) here so forum experts can take a look.
Many thanks!
Message 12 of 12
Thx 4 your reply. Have lost the file in question, will be creating the design again. If I'm still having a problem, will send the file.
