Inventor Forum
Retrieve Dimensions of iParts
4 REPLIES 4
EECLTD
709 Views, 4 Replies
I have a simple iPart for a steel plate. Users input the plate WIDTH, HEIGHT and THICKNESS. After the plate is created the user adds holes as required. Several plates are constrained in .iam file creating a welded assembly. Welded assembly is then brought into idw where it is dimensioned. Each plate is also brought into idw where it is dimensioned.
In the idw is it possible to use retrieve dimensions to get the plate size? The iPart seems to make the original sketch invisible?
When the plate is a standard part with the same user inputs, retrieve dimensions in the idw work just fine.
Inventor 2010
4 REPLIES 4
in reply to: EECLTD
iParts are similar to content center and derived parts in that
they are a solid body controlled by parent driven parameters. They do not
contain a sketch.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
EECLTD
in reply to: EECLTD
Any suggestions on another way?
in reply to: EECLTD
I too would like to retrieve dimensions from an ipart. Sounds like a wishlist item?
in reply to: EECLTD
An iPart "Child" is a derived part. There are no dimensions there to
retrieve.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
