I have a simple iPart for a steel plate. Users input the plate WIDTH, HEIGHT and THICKNESS. After the plate is created the user adds holes as required. Several plates are constrained in .iam file creating a welded assembly. Welded assembly is then brought into idw where it is dimensioned. Each plate is also brought into idw where it is dimensioned.
In the idw is it possible to use retrieve dimensions to get the plate size? The iPart seems to make the original sketch invisible?
When the plate is a standard part with the same user inputs, retrieve dimensions in the idw work just fine.
Inventor 2010
