restoring hatch
restoring hatch
Message 1 of 11
restoring hatch
How do I restore the hatch in section A-A and detail C in Inventor 2019? I turned it off so I could remove the rib hatching in the view.
Replies (10)
Message 2 of 11
JDMather
Do you have any prior AutoCAD experience?
You can add Hatch in Inventor in the same way that you do AutoCAD.
Message 3 of 11
Did you do the hatching as a sketch in the view or right on the view? How did you leave out the rib? I haven't used AutoCAD since 2000.
Message 4 of 11
JDMather
Click view.
Hit S on the keyboard.
Project Geometry hatch boundaries.
(add additional boundary lines/arcs as needed)
BTW - you have a lot of repeated dimensions and dimensions shown as both controlling and as reference.  I would consider this poor practice in detailing a drawing.
Message 5 of 11
Are the lines that remove the rib sketch lines or another type of line?
Message 6 of 11
JDMather
Draw (sketch) them - just like in AutoCAD years ago.
I forgot to change the lineweight, but you can also make them thicker to match the part.
Message 7 of 11
I did that, so do I select them with the rest of the projected geometry, or do I do something else with them?
Message 8 of 11
johnsonshiue
Hi Sean,
The workflow is a bit hidden. You need to edit the view and go to Display Options -> check Hatching.
Many thanks!
Software Test Engineer
Message 9 of 11
Can sketch lines be included when I select lines, etc. for projecting the geometry in a sketch?
Message 10 of 11
johnsonshiue
Hi Sean,
I am sorry I am not sure the exact workflow you are asking. Is this in Drawing Sketch or Part/Assembly Sketch? If it is former, I don't believe Drawing Sketch can be projected to another Drawing Sketch. View geometry can be projected to Drawing Sketch though.
For Part/Assembly Sketch, sketch geometry in SketchA can be projected to SketchB.
Many thanks!
Message 11 of 11
I figured out how to do it. Thank you, everyone, for your help.
