Resize window 'copy design properties' tab in the design assistent
Hi everyone!
I was wondering if there is a way to resize the window of the copy design properties tab inside the design assistant.
I use this option for my work a lot and as you can see in the picture the model information its not instantly visible (have to drag the sliders to see which parts I want to select to see). I cannot drag the window borders as is possible with normal windows. Also tried ALT+space but that doesn't give a resize option as well.
Hope someone has a solution!
Kind regards,
Joris Borra
johnsonshiue
Hi! I am sorry I don't think there is a way to do that at the moment.
Many thanks!
Software Test Engineer
SBix26
This is a long-standing limitation in Design Assistant.  Can I suggest something better for this purpose?  Use the BOM Editor in the Assembly environment.  It is much quicker and easier there.  Even if you have to create a temporary assembly just for this purpose, it is still much easier to work with, mainly because you can drag-fill a column, just as you would with Excel.
If that's not clear, or you run into trouble, post back here.
Sam B
Inventor Pro 2022.0.1 | Windows 10 Home 20H2
LinkedIn
Thanks SBix26! Have been trying this and it works great. I will be using this from now on since I was also able to override properties from locked content center files with the copy design properties. (whoops..)
MogensBang8298
Observer
Observer
Bump - i also need to resize window. Its way to small.
GP_24
Same problem with the Where Used dialog box...
