Representation shortcut
jaco011
jaco011
Hi all,
We use representation a lot our current workflow is;
Select parts / subassembly's > right mouse button > move mouse > left mouse button to select "representation..." > select the right one in the pop up menu
We would love to cut down the mouse movements and have a flow like this;
Select parts / subassembly's > press shortcut > select the right one in the pop up menu
I am fine with a few ilogic code lines, to make our own shortcut, but i don't know how to create it.
Inventor doesn't have it own shortcut to representation, see also; https://forums.autodesk.com/t5/inventor-ideas/representation-quick-key-shortcut/idi-p/6835719
Hope someone can help us
-niels-
If you set up this marking menu, you can CTRL+right click and then select the representation after selecting a part/sub-assy.
You can even CTRL+ drag in the direction of the representation command to save another click.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
jaco011
Thank you that works great! I didn't know I could design that menu
