Inventor Forum
Rendering of Half Section View
10 REPLIES 10
Message 1 of 11
ali_raza117
6093 Views, 10 Replies
I want to render a half section view of a assembly,but its showing complete view of assembly,
is there a way of doing it?
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: ali_raza117
Sketch a big rectangle.
Extrude - Cut
Environements>Studio
Render
Return
Suppress or Delete Extrude Cut feature.
Done.
Message 3 of 11
ali_raza117
well i knew it,but its not an appropriate way to do that,may be its the limitation of studio??
Message 4 of 11
What's not appropriate? Inventor Studio renders the current state of the
model.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
Message 5 of 11
You can section individual components as well.
Message 6 of 11
Or this
Message 7 of 11
Or this
Message 8 of 11
ali_raza117
these are good renderings and explain the functionality of the conponents.but my question was that,why doesn't it renders the half section view as seen in assemply environemnt,
Message 9 of 11
JDMather
http://www.augi.com/inventor/submitwish.asp?page=1083
http://myfeedback.autodesk.com
Message 10 of 11
model. The half section view in assembly is a Graphical View" not a true
slice or section.
Message 11 of 11
As for other thoughts on how to do this:
You can create the sectioned part(s) and place those and your main assembly
in a wrapper assembly, then use animate fade and disolve the whole
component(s) to reveal the interior components. Then, if there are moving
parts, animate those.
As far as calling it a limitation, I would say, it simply hasn't had a high
enough priority. There finite resources available and all have to vie for
those resources. As one email advised, one way to get attention to a feature
is to nominate it on in the AUGI forum and get it debated and voted on as a
requirement.
-Bill Bogan
Autodesk, MFG, Technical Publications
