Inventor Forum
Problemas converting IDW to Cad DWG
9 REPLIES 9
Message 1 of 10
tuliobarata
567 Views, 9 Replies
Hi all!
I'm having here some problems when i'm converting my IDW in DWG. Some little problems, that i could just fix on CAD, but there are many drawings, so it becomes a little hard. The worse thing here is that I have to finish this project in DWG from CAD (just like the client want to) cuz in the DWG from inventor these problems doenst exists.
There are a screen showing every problem.
1º - my dimensions on center lines, always get inside the circle(or other geometry), on its center point, even when i use the dimension from the last point of the center line, how can i fix that ? I tried by 3 ways and the 3 didnt work, get from the center line, from the point of the center line and from the circle, always the same error.
http://img195.imageshack.us/i/firstcenterlines.jpg/
2º - My chamfers notes are with the line in the middle of the word, i tried to change the alignment of them on inventor but it didnt work.
http://img146.imageshack.us/i/secondchamfer.jpg/
3º - My dimensions with smalldot instead the standard arrow, on IDW are with normal diameter, but on CAD it increases a lot, there is a wasy to change it?
http://img195.imageshack.us/i/thirdsmalldot.jpg/
4º - The last one: I have some attributes that i have to fill on the IDW, and they always change its place, even a little. When i use CAD 2008 like the first image, every tima that i save the DWG, close ane reopen all the attributes move a little, like those sequences in the image.
With CAD 2010 they just move a little when I convert, but not when i save like cad2008
is it a problem when i convert from Inventor to cad ?
*Using Cad 2008
http://img31.imageshack.us/i/att2008.jpg/
*Using Cad 2010
http://img690.imageshack.us/i/att2010.jpg/
Sorry, but I created only this topic with those questions, to avoid create many topics.
Thanks very much and sorry about my english, i'm still learning.
IV 2013
9 REPLIES 9
Message 2 of 10
yichuan.xing
in reply to: tuliobarata
Hi tuliobarata,
I am sorry, I can't open the attached pic you provide. Could you please recheck them? Thanks.
If it is possiblem, could you please provide us the data sets you reproduced the problem. (It will be great!)
Guy Xing
Guy Xing
Quality Assurance Engineer
Inventor Team
Autodesk, Inc.
Message 3 of 10
tuliobarata
Hi Guy Xing,
Sorry, but here the link is working normally
I created one IDW with these things that i got the error, follow the link with all ziped, files and images.
http://rapidshare.com/files/316136917/Inventor.zip.html
there are 2 CAD files, one that i saved many times on cad2008 and one from 2010, this time the file that i saved on 2008 didnt get the atts moved like the other time, dont know why
Túlio
IV 2013
Message 4 of 10
yichuan.xing
Hi Túlio,
Many thanks you provide me the data set. But it can't be download by free Rapid Share user.
So could you please do me a favor to send to my mail : yichuan.xing@autodesk.com or change the premission about downloading the data set for free user.
Guy
Guy Xing
Inventor Team
Autodesk, Inc.
Message 5 of 10
tuliobarata
Hi man,
Its me who thank you for helping me. Sorry about rapidShare, i didn't know about these permissions.I forgot that i can attach files here too, so i'll attach it here, anything just say it.
Thanks again,
Tulio
Edited by: tuliobarata on Dec 7, 2009 8:32 AM Edited by: tuliobarata on Dec 7, 2009 8:33 AM
IV 2013
Message 6 of 10
yichuan.xing
Hi Túlio,
The data set seems can't be attached successfully. Could you please try again?
Guy
Guy Xing
Inventor Team
Autodesk, Inc.
Message 7 of 10
tuliobarata
Sorry man, i dont know whats happening here when I try to attach the file, I tried again.
Thanks!
I sended to your email, i dont know why but i cant attach files here.
Thanks! Edited by: tuliobarata on Dec 9, 2009 8:16 AM
IV 2013
Message 8 of 10
yichuan.xing
Hi Tulio,
I got your data set via mail. Here are answer for you:
1. We can tracking this with #987672 in our interal discussing.
2. About the question two. Please using Best Visual Fidelity when you DWGout. The problem will solve.
3. This problem has been solved in latest build, not 2010.
4. Unlucky, I can't reproduced this. Could you please also attached the configuration file when you dwgout? Then I can try with your sepical configuration.
Guy
Guy Xing
Inventor Team
Autodesk, Inc.
Message 9 of 10
tuliobarata
Hi Yichuan,
Thank you very much for helping me.
Sorry about my new quest, forgive my ignorance please, but:
1-This tracking is about this topic or about a problem like the number one mine ? I tried to replace de ID in the topic link, but didn't work.
2- I really didn't know what was this option for, i never used it, worked perfectly!
3- By 'latest build' you mean a new version than 2010 ?
4- The only configuration is that .ini right ?
As i can't attach files, follow the content of that file:
[EXPORT SELECT OPTIONS]
AUTOCAD VERSION=AutoCAD 2004
CREATE AUTOCAD MECHANICAL=No
USE TRANSMITTAL=No
USE CUSTOMIZE=No
CUSTOMIZE FILE=Y:\10-ARQUIVOS INVENTOR\00-Inventor\00 - Inventor 2009\Design Data\DWG-DXF\FlatPattern.xml
CREATE LAYER GROUP=No
PARTS ONLY=No
[EXPORT PROPERTIES]
SELECTED PROPERTIES=
[EXPORT DESTINATION]
SPACE=Model
SCALING=Text
ALL SHEETS=Yes
MAPPING=MapsBest
MODEL GEOMETRY ONLY=No
EXPLODE DIMENSIONS=No
SYMBOLS ARE BLOCKED=Yes
AUTOCAD TEMPLATE=
DESTINATION DXF=No
[EXPORT LINE TYPE & LINE SCALE]
LINE TYPE FILE=C:\menuacad\Sucrana\TEMPLATE\solution.lin
Continuous=Continuous;0,
Dashed=DASHED;0,
Dashed Space=DASHED;0,
Long Dash Dotted=DASHDOT;0,
Long Dash Double Dot=DIVIDE;0,
Long Dash Triple Dot=DIVIDE;0,
Dotted=DOT;0,
Chain=DASHDOT;0,
Double Dash Chain=CENTER;0,
Dash Dot=DASHDOT;0,
Double Dash Dot=DIVIDE;0,
Double Dash Double Dot=DIVIDE;0,
Double Dash Triple Dot=Continuous;0,
Thanks very much! And sorry again about some doubts of mine.
Túlio
IV 2013
Message 10 of 10
yichuan.xing
Hi Túlio,
Thanks for using Inventor and Inventor DWGout.
1. The ID is about the known problem in interal tracking system. So there is no topic link when you search with the ID.
2. The option will achieve the best visual results for exported objects.
3. The latest build is 2011
4. Thanks for sharing the ini file. I try to reproduced this on my Inventor R2010 and AutoCAD 2010, but failed. I attached the exported result, could you please recheck it will also have the problem? Addtional qeustion, how many times do you save and reopen the DWGout result?
Guy
Guy Xing
Inventor Team
Autodesk, Inc.
