Rendering Inventor Assembly Files in the Cloud
What is the process for Rendering Assembly files in the Cloud. We have credits to use for rendering
How long does the rendering process take?
Cheers
James
kelly.young has edited your subject line for clarity: Rendering
blair
I believe this is only for rendering in Autocad and not Inventor.
Delta Tau Chi ΔΤΧ
-niels-
Cloud rendering is also available in 3DS Max, Inventor does not have that option to my knowledge.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thanks for the responses
@-niels- what tutorials/books would you recommend for learning 3DSMAX?
Is the Cloud rendering of higher quality than 3DSMAX?
Cheers
James
-niels-
Hi @Anonymous,
I guess it depends on your options, i'm not officially trained in 3DS Max but i learned by watching tutorials on youtube.
Here's a list i made when i got started with it, which are for Mental Ray:
If you're interested in using 3DS Max to make renders, but don't know how to start, try the tutorial by Jakub Reichman.
Link: https://www.youtube.com/watch?v=P8p6L6TZkOY
The people over at Design&Motion also have a Tutorial on this, you can find it here:
http://designandmotion.net/autodesk/max-morgan-a-minimalist-guide-to-rendering-in-3ds-max/
And you can find some more tutorial videos by Marion Landry here:
https://www.youtube.com/playlist?list=PLowqs8sl9-jv_B1VIOBrWd89aCf6DjbDW
Nowadays i really like using Pluralsight, but Lynda.com is also a well reputed learning site.
Those are subscription based sites though, but if you're willing to spend a little on learning they offer a wide range of programs.
As for books... it might be a good question to ask on the Max forums, might even be some topics about it already so search first.
I think that's not the correct question.
3DS Max cloud rendering is dependent on which renderer you use in your scene as not al materials are compatible with cloud rendering.
(i use Arnold nowadays and that isn't supported as far as i know)
You still have to set everything up in 3DS Max, you just outsource the rendering to the cloud and whichever rendering engine is used there.
So as an answer to your question: i haven't really used cloud rendering because of limitations and so can't comment on quality differences.
Hope that helps. Smiley Wink
Niels van der Veer
The Netherlands
Thanks Niels
Another option would be to push your assembly over to Fusion 360. It have Cloud rendering.
Fusion is much easier to learn than 3ds Max.
