Rendering Clear Glass Inventor Studio
Using Inventor 2018
When rendering in studio how is it possible to have Glass/clear as clear when rendered?
It always looks less than clear
JS
kelly.young has edited your subject line for clarity: Rendering
Xun.Zhang
What's the effect of clear transparency? Is there any sample image to show what you like?
Thanks!
Xun
blair
Check the color of the lights/lighting in your model. Most likely they are to the tan/yellow spectrum.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
kelly.young
Autodesk Support
Autodesk Support
@Anonymous can you post a part showing what you are trying to render?
Is it flat, cylindrical, complex?
Assembly with things behind it to show or individual part?
White presentation background or old warehouse etc?
I'll show you how to do it generically, but depending on shape and how you have things setup it can vary.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
