Using Inventor 2018
When rendering in studio how is it possible to have Glass/clear as clear when rendered?
It always looks less than clear
JS
kelly.young has edited your subject line for clarity: Rendering
Solved by kelly.young. Go to Solution.
Check the color of the lights/lighting in your model. Most likely they are to the tan/yellow spectrum.
@Anonymous can you post a part showing what you are trying to render?
Is it flat, cylindrical, complex?
Assembly with things behind it to show or individual part?
White presentation background or old warehouse etc?
I'll show you how to do it generically, but depending on shape and how you have things setup it can vary.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
