HI !!!
My drawings all are very small dimensions only. all parts are in micron level. Then how to increase zoom level in inventor part? If any options are there.
Solved by JDMather. Go to Solution.
Can you attach an example part here?
How to select that face?? I can't do this. Zoom option is enough.
I had to right click and use the Select Other tool to select that face.
I also recommend that you install the Updates for 2018.
