I am trying to get a nice render in Inventor 2014 pro and keep getting these wierd white dots all over haha i dont know how to explain it.
see attached screenshot, does anyone know if there is some ideal setup or is it meant to be like this?
Solved by sam_m. Go to Solution.
Its a bug in 2014. And I don't believe it has been fixed yet.
There a long topic about it already:
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2014-Renderings-Look-bad/td-p/3920108
It sounds like something has changed in the kernal for 2014 and thus the raytracing is nuked. There's no fix atm (and potentially there might not be one) and a number of people are waiting for long-term advice from AD about it. Read the topic for more info.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Sam M.
Thanks for the replies, i assumed it was something on my end.
