I am extremely new to Inventor and I'm hoping I didn't just really mess things up. So in advance thank you for your patients with me.
I built a large number of parts and then built an assembly. When building the parts I wasn't considering using a proper naming convention so the parts would be more easily accessible in the future when working on other projects. I read up on how to rename the parts and what I found suggested that I use Design Assistant select the assembly, right click on action and choose rename then right click on name and select change name, select open and then save. I did this for nearly 50 parts. When I opened up Inventor all but a handful of parts in the home screen no longer have an image and if I try to double click them I get a message stating that they can not be found. However, I can still open the assembly but the strange thing is that all of the name changes are reflected within the assembly. I know I have some cleanup to do somewhere but I have no idea where to start or what to do. Any help would be much appreciated.
Josh
Solved by PaulMunford. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Welcome to the community..
It sounds like you have unresolved components. At the top of your Inventor Browser, right mouse click on the assembly name and select Resolve Files. Go through each one and (re)point them to where they reside. If you just renamed them using Design Assistant than this should've happened (lost/unresolved). Also what version of Inventor are you using? And what service packs/hot fixes/mid-year releases did you apply?
Mark Lancaster
& Autodesk Services MarketPlace Provider
thank you for getting back to me. I am using the Autodesk Inventory Professional 2016 version. I apologize but I am having a hard time following your directions as stated. When I right click on the name I do not get the option to resolve files.
Josh
Thank you for breaking down the basics...So glad I didn't break anything to serious
