Hi Everyone
My customer set a new procedure about parts number and files name.
Unfortunatly, it look likes i am the only one (or Almost) working with bolted connections.
I have created my own librairy with the template of parts # i want.
However, i also need to have those harware parts not located in the content center files in my vault, but in my project folder.
Question, : is this a fast way to place all files generated by bolted connection to the folder i want. And those files must be in read/write.
Thank you
Solved by jan_priban. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Hi! You can change the default desktop content location (Projects -> Folder options -> Content Center Files). Whether or not the CC part is editable depends on how it is inserted (Standard vs Custom). By default, the parts inserted from Bolted Connection are all standard parts.
You can create another project so that CC folder is editable and you can modify as you wish. However, it can lose its link to the CC library. Do you mind elaborate the need to have this workflow?
Many thanks!
as Johnson suggested and you know, you can define folder, where IPTs generated by Content Center are stored.
This folder is/gets type of "Library" folder, which means files stored there can't be modified. By default (and it is not possible to change) Bolted connection generates bolts/washers/nuts in this "Content Center Files folder". So currently it is not possible to have Content Center files editable.
Only one existing way is instance content center part As Custom, but as said, Bolted Connection does not allow it, Bolted Connection always generates content center parts As Standard under library folder "Content Center Files folder"
Regards
Jan Priban, Autodesk Content Center team
