Inventor Forum
Rename factory files and maintain original associations
4 REPLIES 4
tmoxam
372 Views, 4 Replies
Is it possible to rename/regenerate factory members and have them maintain their association with an iassembly?
i have an i assembly with 6 iparts. the assembly has 70 or so variations. Each of the 6 iparts contain 40 - 80 factory members.
i have completed drawings for all files, assemblies and parts. Now, (of course now) i have been asked to add a "B"  in front of the part number. (part number = member file name). File name is 26075-24 and now will be B26075-24. I am worried that everything will go for a ship if i generate these new files. All drawings will be pointing to wrong files. All iassembly configurations will have to be re-done from scratch.
is there a way to do this keeping the original associations?
4 REPLIES 4
Frederick_Law
in reply to: tmoxam
You need to manually "reconnect" all of them.
Cadmanto
in reply to: tmoxam
Do you have Vault?
Because I am pretty sure I have done renames and copy designs of factory's as well as the members within vault maintaining connections.
Why do you have 2 threads going asking basically the same question?
https://forums.autodesk.com/t5/inventor-forum/rename-factory-members-and-maintain-association/td-p/8...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
tmoxam
in reply to: Cadmanto
Thats what i was hoping. (to use vault) i was checking first for a good procedure.
i was un-able to delete the second forum post.
Cadmanto
in reply to: tmoxam
See the attached link for renaming factory members in Vault.
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
And see this link for using copy design within Vault to copy factory's and members.
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Inventor Pro 2020
Best Regards,
Scott McFadden
