In Inventor 2023 I crated this pattern. Now I changed my mind, and I would like to remover the two parts and keep just the assembly.
If I try to edit the pattern, I don't see a way to unselect the parts.
In the editor there is no window where I can remove them.
The only way I see is delete the pattern and redo it from scratch.
Is there a way to just remove components from a pattern without having to redo it?
Thank you in advance.
Solved by andrewiv. Go to Solution.
When you edit the pattern, all three items should be highlighted, both in the browser and graphics window. Use Ctrl+click to de-select the parts.
Andrew In’t Veld
Designer
You can suppress instances in the pattern. Is that what you're looking for?
Andrew In’t Veld
Designer
I used Solidworks and there an option to skip the instances I didn't want to see/use. I am just asking if the same option is available.
The same option is not available that I know of. The closest thing is you can suppress elements of the pattern, except for the first element, or you can suppress components in the elements.
Andrew In’t Veld
Designer
