Hi all,
I know reducing file size is a topic that has been discussed elsewhere, but I haven't found a topic that discussed exactly what I'm looking at.
My company makes units that are essentially a box/enclosure with a lot of internal components, some of which penetrate through the enclosure and become the interface with our clients other equipment. When we provide models (.stp) to our clients, it's in our interest to remove all of the internal detail so that a) the client doesn't get all of the construction detail, and b) the file size is not ridiculous. All they really need is the enclosure + external interfaces.
I'm wondering what the best way to go about removing all of the internal detail is? Sorry if there is an obvious answer that I should know, but I've never come across this previously. I've tried the obvious 'create simplified part' and 'shrinkwrap' commands, but this doesn't remove internal detail, and also doesn't result in a significant file size reduction for me.
I could go through and manually remove individual internal parts that don't come out of the enclosure, but because of the number of parts involved, this is again a very time consuming process.
I tried modelling a solid box of the enclosure that 'covers' all of the internal detail and then save the whole assembly as a surface, but I still got all of the internal surfaces as well. Is there an easy way of doing this that I am missing?
Thanks in advance,
James
(Sorry, I can't post examples)
Hey there.
I have never used this functionality myself, but I've heard about it.
I'm fairly certain Shrinkwrap can handle what you want.
It gives you one solid with more or less detail depending on the settings. And in worst case, you can do as stated, and fill it internally after having shrinkwrapped it, since it comes out as one solid.
Simplify and shrinkwrap are the tools you should be using and when you create "envelopes" you only include them and can remove internal details,etc..
There are quite a few tutorials on youtube..
I'd start learning by watching some of those..
https://www.youtube.com/watch?v=No4MF1yBp4k
