Inventor Forum
Remove Image Links to DWG
28 REPLIES 28
Message 1 of 29
7608 Views, 28 Replies
I have a DWG with some links to images on.  I would like to remove these links but am having a bit of a hard time.
See attached screenshot of the missing images.
I have tried to use 2 different macro's to remove these but it appears these are not OLE objects (which the macro's remove).
There is no delete menu item when you right click on the image like either.
28 REPLIES 28
Message 2 of 29
Cadmanto
Cadmanto
Miles,
Just a shot in the dark here, but have you tried doing a file save as copy, calling up the newly saved file and see if you can delete them in that file?
Also, what version are you running?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Miles,
Best Regards,
Scott McFadden
Message 3 of 29
yannick3
yannick3
Hi
Maybe you can try with manage link icon in drawing environment
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Hi
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
Message 4 of 29
in reply to: yannick3
Hi to you both!
I have tried saving a copy and it reacts the same as the original.
The links button is greyed out on my software.
I am running 2014 pro.
Hi to you both!
Message 5 of 29
A workaround I would suggest would be to 'save as' and use the .idw format. Then open this and save back as the .dwg.
This should remove any phantom connections as it does not transfer them to the .idw
Hope this helps
Hope this helps
Message 6 of 29
scottmoyse
scottmoyse
Hope this helps
Nice touch Kokoza! That worked a treat. This shouldn't be happening anyway. But what a PITA. At least this means you don't have to recreate the drawing.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hope this helps
Scott Moyse
Message 7 of 29
gavbath
in reply to: scottmoyse
gavbath
I had this issue a while back and looked at the internal workings of the file through VBA and found the links.
While I could see the erroneous links, I couldn't delete them programmatically.
That's an awesome workaround though Kokoza! Well done.
I think I'll build an automated routine to do that.
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
Gavin Bath
Message 8 of 29
gavbath
gavbath
Here's a very rough and ready macro that automates the process:
Sub Main()
    Dim doc As DrawingDocument
    Set doc = ThisApplication.ActiveDocument
    Dim existingfFileName As String
    existingFileName = doc.FullFileName
    Dim trimmedStr As String
    trimmedStr = Left(existingFileName, Len(existingFileName) - 3)
    Dim newFileName As String
    newFileName = trimmedStr & "idw"
    Call doc.SaveAs(newFileName, True)
    Call doc.Close
    Dim newIdw As DrawingDocument
    Set newIdw = ThisApplication.Documents.Open(newFileName, True)
    Dim newDwgFileName As String
    newDwgFileName = trimmedStr & ".dwg"
    Call newIdw.SaveAsInventorDWG(newDwgFileName, True)
    Call newIdw.Close
    Kill (newFileName)
    Name existingFileName As existingFileName & ".old"
    Name newDwgFileName As existingFileName
    Dim newDwg As DrawingDocument
    Set newDwg = ThisApplication.Documents.Open(existingFileName, True)
End Sub
You'll have add it to a module in the application project. If you don't know what this is, it's probably not a good idea using this macro.
To use the macro:
1. Open the Inventor DWG
2. Run the macro
3. That's it
You'll end up with a new dwg with the links removed. The old bogus one is in the same folder with a ".old" extension.
Hope this helps someone.
Gavin Bath
Sub Main()
    Call doc.Close
    Call newIdw.Close
    Kill (newFileName)
End Sub
To use the macro:
2. Run the macro
3. That's it
Gavin Bath
Message 9 of 29
scottmoyse
in reply to: gavbath
scottmoyse
For anyone who wants all the steps to do this and use the macro @gavbath has written. You can take a look at this blog post, which contains a few additional details than this video:
Scott Moyse
Scott Moyse
Message 10 of 29
jamesjung
jamesjung
Is there a way to remove 3rd party links on a part file?
Message 11 of 29
scottmoyse
in reply to: jamesjung
scottmoyse
Try saving as an idw, then back to DWG again.
Scott Moyse
Scott Moyse
Message 12 of 29
Thank you so much! I have been pulling my hair out trying to fix this, and your solution worked perfectly. Thanks again
Message 13 of 29
Does anybody have a copy of the script used in the video, it appears to be slightly different to the one posted. I'm having problems with ghost links in inv2018.
Message 14 of 29
johnsonshiue
johnsonshiue
Hi! You should be able to go to Tools -> Link -> break link. If it does not work, it means the link may be corrupted. Please share an example here so forum experts can take a look.
Many thanks!
Software Test Engineer
Many thanks!
Message 15 of 29
in reply to: johnsonshiue
This appears to be a common problem after doing a bit of googling on the subject. I can't check in a drawing to Vault as it as there were images within the drawing border which even though they have been deleted from the drawing appear to linger on as ghost links and stop the drawing from being checked into vault. Additionally the tools links option is greyed out.
Message 16 of 29
johnsonshiue
johnsonshiue
Hi! What Inventor release are you on? I recalled there was an issue on 2015 or earlier, which had been resolved already.
Try this and see if it helps. Copy and paste an image file with the same name to the folder. Then resolve to the new image file. Now, are you able to break the link using Link command?
Many thanks!
Many thanks!
Message 17 of 29
t_fransman
t_fransman
the macro does not seem to work on an idw.
 Complains on this line i think it's line 15
Call doc.SaveAs(existing file name, True)
Can you help this is in our templates and linking our copy design together into a big list of bad ref and copy Design is almost impossible to use at this point.
Message 18 of 29
johnsonshiue
in reply to: t_fransman
johnsonshiue
Hi! Like I mentioned on the other thread, the drawing is likely corrupted. You may want to start a new one and copy the sheets from the old drawing to the new one.
Many thanks!
Many thanks!
Message 19 of 29
save inventor drawing as .idw. Reopen drawing in inventor and save as .dwg. This will remove all ghost image links.
Message 20 of 29
t_fransman
t_fransman
Tried that, even ran the macro, the macro did not work. and it did nothing. The reason was it was actually used in a sketch block.
