remove color segments
Message 1 of 11
In the 2015 part attached in the section colored Yellow how do i remove the inner Black Stripes so the color is the same as the part (grey)
Remove the color Black only in the Yellow Section of the part
regards
Ray
Replies (10)
Message 2 of 11
admaiora
Hi Ray,
not sure if it is what you are looking for
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 11
Hi admaiora
Close except only the color in the yellow segment. The Black remains above the Yellow section
I was thinking of maybe somehow a Split is required
thanks
Message 4 of 11
admaiora
Like this?
It's the same of the other image. It was only a reflection, but the road is the same.
Admaiora
Message 5 of 11
admaiora
Ok. I think i have understood when do you say "above" .
If like this.. yes you have to split faces (using a plan for example)
Admaiora
Message 6 of 11
Yes that is what i wanted.....how did you get the result please?
Message 7 of 11
admaiora
Admaiora
Message 8 of 11
Very close but i get a small amount of Black left on the inner ring after the Split Tool. Thanks
Message 9 of 11
admaiora
You can proceed for that in the same way, or
You can rethink your design choosing a modeling that can simplify your colouring selection.
Admaiora
Message 10 of 11
ok..see if i need to remodel so as to get rid of the black color in the inner circle
Ray
Message 11 of 11
JDMather
Do you realize that this line is not Horizontal and therefore you have a cone rather than a cylindrical face?
