Different but related:
We are looking into purchasing a laser cutting/etching machine. Performing a Save Copy As... by right-clicking on the Flat Pattern node in the browser, one can export a DXF or DWG.
The most important aspects are as follows:
*The exported drawing is full scale
* Counterbore/Spotface/Countersink lines will be in a named layer that can be turned off
* Bend lines and Bend Extent lines are each in a named layer and can be turned off
* Laser Etched lines are in a named layer and can be distinguished from cutting lines
All good.
In the meantime, we are exporting out drawings to DWG and sending them to laser cutting vendors.
After learning a bit about laser cutting machines, I now note that these exported IDWs:
* Are at the scale presented in the drawing file (OK, vendor can scale)
* Bend lines will appear in a named layer that can be turned off (good)
* Text, drawing border and title block can be turned off (good) BUT ...
* The part outline (for cutting) plus Counterbore, Countersink, Spotface and laser etched lines all are put into the visible layer.
This requires us to additionally process the drawing so that these non-cut items are distinguishable or deleted (tedious, error prone and undesirable).
Wouldn't it be nice ...
If we are exporting the drawing for our vendors anyway, is it possible to make:
* Etched lines export to a separate, named layer (so the machine will etch and not cut) and
* Counterbore, countersink, spotface lines export to a separate, named layer (so they can be turned off or deleted)?
Note: Thru holes should remain part of the Visible layer so that these are cut.
Another nice thing for laser cutters:
We do a lot of pilot holes for match drilling and installing rivets. I would love:
* Inventor having a special "Pilot Hole" feature. The hole may appear as a small diameter hole (possibly settable) in a drawing but it is really only a location and is distinguishable from normal holes.
* These pilot holes would be exported to separate, named layer which the laser cutter can be programmed to recognize.
* Pilot holes will not be cut as round hole; rather, the machine will just perform a single pulse thru the material at that location.
Again, this would be nice to have whether exporting a flat pattern from the model file or saving an IDW as a DXF or DWG.
I am still using INV2024. Please excuse me if some of this is handled in later versions.
Inventor Pro / Vault Basic
