Stress Analysis fails to run because parts use the same name
DustinBTW
DustinBTW
I have a Frame that I am attempting to run a simple stress analysis on, but when I Simulate, It fails because I have multiple components with the same name. This was fully assembled with the frame generator, so of course, it would reuse Items. Can someone shed some light on this. It would be much appreciated.
I found something about this issue that was resolved in a patch, But I updated to 2021.3 and receive the same error.
Intel Pentium 2 355mhz
128mb Ram
ATI 3d Rage Pro 8mb
10gb Harddrive
johnsonshiue
Hi Dustin,
This one looks like a bug or a limitation to me. The browser name was indeed changed but FEA still complains about the duplicate name. Go to Manage -> Rebuild All. Then the Simulation can proceed.
Regardless, Rebuild All should not be needed.
Many thanks!
Software Test Engineer
MadoreJacob
Hi johnsonshiue,
The Rebuild All command does not work for us, running Inventor 2024.
Any other ideas?
CGBenner
@MadoreJacob
Hello, are you experiencing the same problem as the original poster of this thread?  If not can you share some more details of what you are struggling with, and what you have tried so far?  Thanks!
Chris Benner
MadoreJacob
Hi Chris,
Yes, I am experiencing the same issue as the original poster and I've only tried the Rebuild All command, I'm not sure what else to try.
johnsonshiue
Hi! Another possibility is that somehow there are two components named the same in the browser. Go to Assembly ribbon -> Productivity -> Rename Browser Nodes -> change it to File Name. After that, does FEA run fine now?
Many thanks!
MadoreJacob
Hi Johnson,
Yep, that worked, thank you!
