Inventor Forum
Reference part in 1 idw only, not in others, how ?
2 REPLIES 2
tobias
242 Views, 2 Replies
Is there a possibility to have a part are an assembly set as reference in 1 drawing (idw) only ?
Now, when I set as reference, it is as referenced every where. That is ofcours not what I want.
Any solutions ?
Thanks.
Tobias
The Netherlands
Inventor Pro 2025, Vault Pro 2025, AutoCad Electrical 2025.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Tags (3)
2 REPLIES 2
dave.cutting
in reply to: tobias
When you say set it as reference I assume that you're changing the document settings of the part and making it reference. That way it will  be reference everywhere.
For a part with its BOM structure still as normal, you can right click on it in the assembly browser, find BOM structure, and set it to reference there. It will only be reference in that particular assembly.
Is this what you're trying to achieve?
Dave Cutting
tobias
in reply to: dave.cutting
Hi @dave.cutting ,
Yes, this is it. Thanks!
I changed the BOM in the assembly, and then it went wrong.
Tobias
The Netherlands
