Redefine model in IAM
jan26BTZ
Message 1 of 18
jan26BTZ
Hello
I run Inventor Pro 2024.
How can i redefine x, y, z in my assembly?
Sometimes the part that i insert isn´t correct in any way if you compare it with the cube.
It must be a easy way to fix that.
The attached file is a sandwich wall that a need to change.
i need it to be as i marked the surface in the model.
/J
Replies (17)
Message 2 of 18
CCarreiras
Hi!
you have to upload also the parts.
The files iam dont carry the files ipt inside, only the links how parts are connected.
Anyway, you can't change the xyz directions in any CAD software, but... you can change the cube orientation.
Since you cannot change the XYZ, you can place the parts with constrains, respecting the direction you need.
CCarreiras
Message 3 of 18
jtylerbc
The attached file can't be opened because you didn't include the parts.  An assembly doesn't contain the geometry, just locating information for the parts.  The part files have all of the geometry.
That being said, no, there isn't really a way to redefine the coordinate system of the assembly.  The problem is most likely that the parts were built in an odd orientation.  The assembly probably isn't the source of the issue.
Message 4 of 18
SBix26
When placing a component, right click and you will find Rotate X 90°, Rotate Y 90°, and Rotate Z 90° commands.  You can use those to orient the component you are placing in 90 degree increments before placing it.  Then you can use Place Grounded at Origin to nail it in place (if appropriate) or use Constraints and/or Joints to relate it to other components or the origin.
Sam B
Inventor Pro 2024.2 | Windows 11 Home 23H2
Message 5 of 18
johnsonshiue
Hi! Is the issue about the ViewCube (view orientation) inconsistent with the XYZ? Or, you do want to redefine the coordinate system with respect to the geometry?
Here is a short video showing the workflow to reset ViewCube so it is in Z-up orientation.
Many thanks!
Software Test Engineer
Message 6 of 18
jan26BTZ
Hello
Sorry for the late reply.
I had other things to do yesterday so I didn't have time to check the email.
Attached missing files
Message 7 of 18
jan26BTZ
That movie help me alot. thanks
Message 8 of 18
jan26BTZ
Hello It is not so easy to explain so that everyone understands. Especially not when you are from Sweden and not so good at English. 🙂 The video helped a lot, but not completely. Sometimes when I insert an .IPT into an .IAM I notice after a while that none of X,Y,Z match the cube with the detail. I don't know what I'm doing wrong because 90% of the time it's always right. I would then like to be able to determine and "point" to the surface of the detail that I e.g. want like Z.   REG
Jan
Message 9 of 18
jan26BTZ
That works great, i should always do that from now on!!
Message 10 of 18
CCarreiras
Hi!
This issue happening now is probably because you have different specs (regarding orientation) between parts and assemblies.
Following the video, you can set the assembly template and the parts templates (solid and sheet metal) with the same orientations, the orientations that you need.
That's what i did for my templates, and now i don't have to worry about rotate the parts when I'm placing them in the assembly.
  1. Open the templates (iam and both ipt)
  2. Reset the cube orientation
  3. set correct orientation (following the video instructions)
  4. Save the changes as a new template, and the future files will be fine.
Note: The work already done, you will have to change it manually thou, this will only affect the new jobs.
CCarreiras
Message 11 of 18
johnsonshiue
Hi! In most cases, it is about the ViewCube not aligned to the XYZ desirably, not the geometry misaligned to XYZ (modeling issue).
Another thing you may want to do is to enable all origin planes in your iam and ipt files. This will avoid the automatic isometric view rotation when you try to create a new sketch. The auto rotation helps new MCAD users to select a plane before creating a 2D sketch. However, it rotates the model to Y-up biased isometric view.
Many thanks!
Message 12 of 18
jan26BTZ
Hello
Today it happened again, what sometimes happens.
All of a sudden when I'm sitting and working with an assembly, I discover that the coordinate system is no longer correct??
Why did it happen like this? and how can i restore it?
Attached is the file in step format
i dont know how to attach moore than 3 files in the same post.
Message 13 of 18
CCarreiras
Hi!
The step file doesn't help to find the issue.
You can zip the work folder with all the files inside and send it... the zip file.
CCarreiras
Message 14 of 18
jan26BTZ
Hi
I fixed it in my own way.
I inserted a new part that was defined correctly. then I gorounded it before putting it together with the lost part that was undefined.
Woala! thats it.
I became my own expert all of sudden.
Message 15 of 18
jtylerbc
@jan26BTZ wrote:
Hi
Woala! thats it.
None of that has any effect on the assembly coordinate system.  Also, the assembly coordinate system is a fixed thing that can't be redefined.
I'm not sure we understand the problem you're trying to describe.
Message 16 of 18
jan26BTZ
When the problem occurs, neither the cube nor the XYZ symbol on the lower left matches any of the surfaces on the model,
the model is completely lost.
Message 17 of 18
johnsonshiue
Hi! If it is in an assembly, maybe the part is placed very far away from the origin. Please right-click on the part in the browser -> iProperties -> Occurrences -> check the offset values. Reset them to zero so that the part is moved back closer to the origin.
Many thanks!
Message 18 of 18
jan26BTZ
I try that when it occurs again.
Thanks.
