Rectangular Pattern Within Boundary Sketch
kevinmullen88
Message 1 of 8
kevinmullen88
I'm using the 3d model rectangular pattern within a boundary sketch in Inventor 2025,
Can someone explain why this pattern is not working. You can clearly see that the feature geometry is within the bounding sketch. I've created a circle sketch, extrusion cut, circular pattern then pattern x and pattern z within the highlighted boundary. I thought this would be a straightforward process. Feedback would be much appreciated.
Cheers
Replies (7)
Message 2 of 8
kevinmullen88
I have changed the hole from 3/4 to 3/8, X pattern seem to work and is bounded. When I try to patten Z I get a failed pattern
Message 3 of 8
kacper.suchomski
Hi
When you duplicate using the pattern of Circle Pattern, the object being defined (and therefore duplicated) is the circle pattern, not the circle itself. So if the Pattern doesn't fit in the boundary, it won't be duplicated at that location.
In summary, your modeling method is wrong. Change the way you model the part.
Kacper Suchomski
Message 4 of 8
kevinmullen88
How would you suggest populating holes for a heat exchanger tube sheet with a triangular pattern ?
Message 5 of 8
kacper.suchomski
This is a regular rectangular pattern. The only issue is that one direction has an angle of 60 degrees, not 90 degrees.
EG 1:
https://youtu.be/3N4-M2QDGbA?feature=shared
EG 2:
https://youtu.be/VB7jygfmXoo?feature=shared
Kacper Suchomski
Message 6 of 8
kevinmullen88
Thank you Kacper. Those video links were a great help.
Message 7 of 8
kacper.suchomski
You can subscribe to the channel to learn more in the future.
Kacper Suchomski
Message 8 of 8
kevinmullen88
Thank you I just did.
