Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm using the 3d model rectangular pattern within a boundary sketch in Inventor 2025,
Can someone explain why this pattern is not working. You can clearly see that the feature geometry is within the bounding sketch. I've created a circle sketch, extrusion cut, circular pattern then pattern x and pattern z within the highlighted boundary. I thought this would be a straightforward process. Feedback would be much appreciated.
Cheers
