Inventor Forum
Rectangular coil model
16 REPLIES 16
Message 1 of 17
1240 Views, 16 Replies
I'm trying to do a rectangular coil for few days now and I'm having many difficulties.
Here is an example of more or less what I'm trying to do.
http://www.uratani-eng.com/english/service/images/201001191115371e1d1aea5e.JPG
Could you help me?
This is what I've made. Inside corners are not curved correctly and I can't really fix it. Also I would like to go to a lower level from the inside, but can't really find a way to bend the pipe, I can't separate last section of it.
I know it may sound silly, but I'm a beginner in 3d designing.
Thank you for help!
Kuba
16 REPLIES 16
Message 2 of 17
TheCADWhisperer
Can you attach the *.ipt file of your attempt here?
The solution will involve a Sweep path generated as the intersection of two surface bodies.
Message 3 of 17
in reply to: TheCADWhisperer
Please find it in the attachment.
Thank you.
Message 4 of 17
TheCADWhisperer
Aren't the bend radii of your Sweep path obviously too small?
You have an outside bend on the resulting sweep, but not an inside bend?
I would expect the fillet in the path to be minimum 7.5  or 7.6 and all of them controlled from one dimension?
If you have a subscription access to the Updates - I recommend that you install them while waiting for someone to post an example solution for your design.
Message 5 of 17
Thomas_Savage
Hello @Anonymous
I have attached 2 Screenshots.
Are either of these screenshots what you wanted?
I changed the radius. And extended, shortened the sweep.
Thomas
Thomas Savage
Design Engineer
Message 6 of 17
My interpretation was additional layers?
Message 7 of 17
in reply to: Thomas_Savage
Thank you very much. That's one problem solved.
Could you also tell me how to solve this layer/levels issue (marked on the attached pic).
Message 8 of 17
johnsonshiue
Hi! I tweak the design a little bit. And also, I use surface pattern to create the geometry for the path easily. The path is too tight and it can lead to same-segment-self-intersecting sweep, which Inventor does not support yet. I make the offset slight bigger.
Please take a look and let me know if you have any question.
Many thanks!
Software Test Engineer
Message 9 of 17
in reply to: johnsonshiue
Message 10 of 17
And is there any simple way to avoid these turnarounds? Because I am afraid it will affect the results of the heat transfer (in this hollow there is a coolant flow).
Please find in the attachment the ideal solution that would solve it. Either that "smooth" or "sharp"
Message 11 of 17
johnsonshiue
Hi! Here you go. You just need to change the path a little bit. Then the sharp turns are smooth now.
Many thanks!
Message 12 of 17
Thank you.
Would there be a way to do it similar like i attached pictures in this post? Would it be complicated? Because I am trying to avoid to have these 180deg turnarounds in the path.
The coil goes from the lower external horizontal layer to the upper external layer then goes to the second horizontal layer from the outside then goes down then in the bottom it goes one layer inside once again then up etc.
Please find in the attachments picture of my drawing (it's pretty bad sorry) and the magnet coil itself (unfortunately I can't disassembly it so the picture may not be really clear as well). If it is not clear enough, I could draw it better / take a better picture of a coil.
Message 13 of 17
johnsonshiue
Hi! There might be a better way to do it. Please take a look at attached solution. In the meantime, I would like to see how these models inspire some ideas from you.
Many thanks!
Message 14 of 17
Thank you again and sorry for being so absorbing.
I changed the approach and tried to do it a bit differently, but again I met different problem. I can't extrude the line which is a layer changer. Therefore I can't really do that layer that will be a pattern up to the top. I have also concern that the angle between this layer changing piece will cause discontinuity there (red color on the drawing).
Please find in the attachment the drawing.
Message 15 of 17
Sorry for forgetting the attachment
Message 16 of 17
johnsonshiue
Hi! I am sorry I don't understand the problem you are having. What do you mean by you cannot extrude and the layer technique does not work? Please be more specific.
Many thanks!
Message 17 of 17
kelly.young
Helllo @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Here is a good way to accomplish what you're looking for using two different 2D Sketches and bringing together within a 3D Sketch using Intersection Curve.
Here's a similar post:
Porcupine Element
Please select the Accept as Solution button if a post solves your issue or answers your question.
Technology Administrators
