Inventor Forum
Rebar Schedule
3 REPLIES 3
1693 Views, 3 Replies
Rebar Schedule
Hi ALL!!!
I am a Inventor user and am in the need for a way to get a rebar schedule made referencing my Inventor parts. Like to know if you can create your concrete walls, slabs, beams etc... and either place rebar in these Inventor files and then create some type of rebar schedule (table?) or something. Or take the concrete walls, slabs, beams etc... and import into another Autodesk product like Revit and have this create the schedules and then export back to Inventor. Is any of this been done or possible? Want Inventor to have the end product.
3 REPLIES 3
Cadmanto
See if this link helps you.
http://forums.autodesk.com/t5/Autodesk-Revit-Structure/Rebar-schedule-with-beam-column-host-info/td-...
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
So it looks like I need to get Revit and the add-on. Correct?
Cadmanto
Yup, that appears to be your best avenue.
Best Regards,
Scott McFadden
