Hi ALL!!!
I am a Inventor user and am in the need for a way to get a rebar schedule made referencing my Inventor parts. Like to know if you can create your concrete walls, slabs, beams etc... and either place rebar in these Inventor files and then create some type of rebar schedule (table?) or something. Or take the concrete walls, slabs, beams etc... and import into another Autodesk product like Revit and have this create the schedules and then export back to Inventor. Is any of this been done or possible? Want Inventor to have the end product.
Solved by Cadmanto. Go to Solution.
See if this link helps you.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Yup, that appears to be your best avenue.
