Inventor Forum
Разрезать круглый логотип на 4 части - Cut the round logo into 4 parts
9 REPLIES 9
Message 1 of 10
simanov_daniil
416 Views, 9 Replies
Доброго времени суток! Я создал круглый логотип, с текстом. Хочу разделить его на 4 части и сохранить по отдельности. Как мне это сделать? У меня не получается разрезать логотип, как пирог ножом
Translation:
Good day! I created a round logo, with text. I want to divide it into 4 parts and save it separately. How should I do it? I can't cut the logo like a pie with a knife
9 REPLIES 9
Message 2 of 10
SBix26
in reply to: simanov_daniil
Translation:
Good day! I created a round logo, with text. I want to divide it into 4 parts and save separately. How should I do it? I can't cut the logo like a pie with a knife
Attach your file here, if you are allowed to do so.  Is the logo a 3D model or a 2D sketch?  What version of Inventor are you using?
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
Message 3 of 10
simanov_daniil
in reply to: SBix26
3d эскиз, 2022
Message 4 of 10
SBix26
Please post the file, or a similar file made up to show the process, or an image.  I can't imagine what a logo made by 3D sketch would look like.
Sam B
Message 5 of 10
CGBenner
@simanov_daniil
Hello.  You may continue to have this conversation here in the English language forum if you are comfortable, but I wanted to let you know that we also have a Russian language Inventor forum, if you would prefer.
Привет. Вы можете продолжить этот разговор здесь, на англоязычном форуме, если вам удобно, но я хотел бы сообщить вам, что у нас также есть русскоязычный форум Inventor, если вы предпочитаете.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Message 6 of 10
simanov_daniil
in reply to: SBix26
Вот образец. В дальнейшем нужно каждую из сторон сохранить в .stl (Формат двоичный, разрешение - высокое). Работаю в Cura. Прошу прощение, inventor 2023
Message 7 of 10
mcgyvr
You didn't specify how exactly you want this cut up but sounds like you simply need to use the "Split" tool and then you can use "Make Components" to save each resulting solid body as its own part. Split part attached
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-349C84EE-2D24-4DFC-A239-AFD55E5441AD
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-6A2FC6BE-45C5-41B3-9476-848F516EBA37
Message 8 of 10
simanov_daniil
in reply to: mcgyvr
Я пытался поделить на 4 равные части, но в cura деталь пустая внутри. Принтер только буквы будет печатать.
Message 9 of 10
mcgyvr
Works fine for me in Cura..
Message 10 of 10
Я все пытаюсь разобраться в этом вопросе. Я создал цилиндр в 2d эскизе. Разделил его на 4 части, но когда создаю компоненты, у меня 1 твердое тело, но почему не 4?
