Доброго времени суток! Я создал круглый логотип, с текстом. Хочу разделить его на 4 части и сохранить по отдельности. Как мне это сделать? У меня не получается разрезать логотип, как пирог ножом
Translation:
Good day! I created a round logo, with text. I want to divide it into 4 parts and save it separately. How should I do it? I can't cut the logo like a pie with a knife
Solved by mcgyvr. Go to Solution.
Translation:
Good day! I created a round logo, with text. I want to divide it into 4 parts and save separately. How should I do it? I can't cut the logo like a pie with a knife
Attach your file here, if you are allowed to do so. Is the logo a 3D model or a 2D sketch? What version of Inventor are you using?
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
Please post the file, or a similar file made up to show the process, or an image. I can't imagine what a logo made by 3D sketch would look like.
Sam B
Hello. You may continue to have this conversation here in the English language forum if you are comfortable, but I wanted to let you know that we also have a Russian language Inventor forum, if you would prefer.
Привет. Вы можете продолжить этот разговор здесь, на англоязычном форуме, если вам удобно, но я хотел бы сообщить вам, что у нас также есть русскоязычный форум Inventor, если вы предпочитаете.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Вот образец. В дальнейшем нужно каждую из сторон сохранить в .stl (Формат двоичный, разрешение - высокое). Работаю в Cura. Прошу прощение, inventor 2023
You didn't specify how exactly you want this cut up but sounds like you simply need to use the "Split" tool and then you can use "Make Components" to save each resulting solid body as its own part. Split part attached
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-349C84EE-2D24-4DFC-A239-AFD55E5441AD
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-6A2FC6BE-45C5-41B3-9476-848F516EBA37
Я пытался поделить на 4 равные части, но в cura деталь пустая внутри. Принтер только буквы будет печатать.
Works fine for me in Cura..
Я все пытаюсь разобраться в этом вопросе. Я создал цилиндр в 2d эскизе. Разделил его на 4 части, но когда создаю компоненты, у меня 1 твердое тело, но почему не 4?
